Replacing dash lights on 94 tlc
federal way washington
I have a 94 tlc. And half of cluster lights are burnt out. Of course its in Speedo side so I can't see how fast I'm going. Do I need to pull steering wheel? I'm putting LED lights to replace bulbs.
Thank you
Ken S
You don't need to pull the steering wheel. There are screws to pull out to take off the black plastic trim. Be careful because that plastic can be pretty easy to crack. I've had mine out a couple times, and I believe it is one big piece that all comes out from above the radio through the dash. Once you get that loose, I believe it is a few more screws and it pulls out (it's been a while, so I don't remember all the details exactly. It's not that hard, but a little time consuming because you want to be very careful to not break things.
I would pull the wheel, it's very easy on an non-airbag truck and gives you much more room to undo the upper bezel and remove the cluster.
