for those with arbs that aren't using arb solenoids, what are you using?
i'm looking for something that will fit their pump but will take 1/4 air line instead of 5mm air line.1973Guppie said:are you looking for something electrical that would replace the solenoid or ? Another option is you can actually purchase all the parts for the solenoid wholesale and build them yourself. I did this and it saves mucho $ off buying them from arb. I don't have any of the details as this was many years ago but I bet you could find the details somewhere out there in cyberland.
let us know what you are trying to achieve? want to get rid of the elecrical, cheaper solenoids? or ?
Noah
nuclearlemon said:i'm looking for something that will fit their pump but will take 1/4 air line instead of 5mm air line.
don't want to build myself as i really don't know anything about them.
5mm air line is an odd size that's not readily available.1973Guppie said:are you looking to beef up the air line or ? that is what I meant by what are you trying to achieve? why do you want to go to a new type of line, etc, etc, etc, more info if possible would help...........
noah
no, arb used british standard pipe thread. not using copper, just want to use the much more common 1/4 line. plastic is reliable if you get a good name tubing like phillips. most companies carry the cheapo stuff that gets brittle easily. also, people don't run the line to the housing long enough for flex, but i'm running a fifth wheel slider hose to take care of that problem.honk said:As far as I could tell the hole in the ARB solenoid is a standard pipe thread and if true you should be able to find fittings to step up to whatever line size you'd like at the hardware store.
Are you by any chance looking to use copper lines instead of the blue plastic supplied in ARB kits? If so, it's probably a worthwhile project. Most people have no problems with the plastic line but to me it still seems pretty fragile even when run inside the frame where possible and tied in place along it's runs.
nuclearlemon said:no, arb used british standard pipe thread. not using copper, just want to use the much more common 1/4 line. plastic is reliable if you get a good name tubing like phillips. most companies carry the cheapo stuff that gets brittle easily. also, people don't run the line to the housing long enough for flex, but i'm running a fifth wheel slider hose to take care of that problem.
