replacement battery clamp
Powell River, BC
Anyone had to replace the OEM battery hold down/clamp bracket? One of mine doesn't have much metal left.
I popped into a couple places today but all anyone had was brackets that went across the width, not the the length like the 80 series do.
Toyodiy shows some kind of weird cage thing (74446-60010) that I don't have for restraining the battery, but mine is just really a simple metal angle with each end twisted for the J hooks.
Stolen pic, but looks like this...
make you own - flat bar and two welded pieces of angle to hold your battery. Built one for my 77 Celica and even plasti-dipped it
I used what I had on hand and it's been good for two years and counting. I took a piece of that galvanized 1-1/2" strap/bar with the holes all along it. I bent it to match the hold down bar and anchored it down through the existing holes. Looks kind of cool too. :cool:
Last time I checked they were still dealer available
Yeah probably. But in my case I was installing a Group 31.
Battery was too wide and too tall for the J hooks.
Good idea, I believe I have a roll of that kicking around. Failing that off to Princess Auto for some aluminium L.
Just to satisfy my own curiosity, what's the part number? 'cause the p/n 74446-60010 I pulled from Toyodiy looks nothing like what I have.
No that's not it. This is too thick to be in rolls. This is in the upright displays with the steel bars at home depot in 36" & 48" lengths. But since that's right next to the angled stuff, in both steel and aluminum, you might as well go with those and not have to bend it.
Wait, there's actually a place called Princess auto?? See now that wouldn't fly in the States. :hmm:
I widened the stock bar with a piece of steel you can see on the left, it's tapped so no nut is needed. Longer j-hooks were easy to find at the auto parts store. I had welded some angle iron to the bar and tapped it to mount my relays so I had reason to make the stock bar work.
