Replaced My Sideview Mirrors Today.
NC
Searched and did not find another thread like this so thought i would post up. If it was already done then i will delete this thread.
Wife got tired of having the drivers mirror shake so i started looking around online. Looked on Fleabay and found some mirrors on there for a decent enough price so i thought why not. Right now i could not afford the Toyota ones. Ordered them and they got here in about 3 days time. Really nice to see that these days. Did not come with any tipe of instructions so out came the FSM. From what i found in there it sad how to take them out but not quite all the way, so i figured out what all i needed to do.
First of all it is not a hard job what soever. Only tools really needed were the following.
10 mm Socket / rachet
Small phillips head screwdriver
Large Phillips head screwdriver
Small straight screwdriver
and the tool to pull the door panel off
This is what i did. You might be able to find a short cut or two.
Started by rolling down the windows. Pulled the inner door panels. Pulled the speakers to be able to get room for my hands for the electrical connectors and finnaly pulled the small black rectangular thing so you could get to the bolts that hold the mirror on. That piece comes pops off at the top and then you pull up and out carefully. Pics will show this.
Back together was the reverse.
I am doing this as a long term thing to see if they hold up what soever. Time will tell. Inside the new mirror itself looks exactly like the Toyota ones. But my old Toyota ones had seen better days. These are black and i am going to leave them that way for the time being. Wife likes them that way, and she drives it. Maybe one day down the road when i do the body work to this thing i might do them in the body color at that time.
Onto the pics. Some might be out of order but you will get the idea.
The fit was good and only time will tell.
If anyone wants i can post up the user from fleabay i got them from. I have no ties / affiliation with them at all.
Again time will tell and i will try to post back every few months.
They look good - please post up the link. They can't be worse than the shaky factory crap.
I would prefer black, it matches everything up on top any way.
nice find dude. Do you know if it's possible to keep the OEM outer shell and simply swap out the guts inside?
Looked into that for a bit but looked like more of pain than what it was worth. The outside of my old ones was not perfect though so that was a pretty easy decision.
No more power? If it still does have power, I assume it's working properly?
These are still like the ones on my 94 yr model. Connector was exactly the same as the stock one. Yes they still work like stock.
Put about 75 miles on them this morning already and it is nicer. Did try to stick a screwdriver under like we do on the Oem ones and could not find a screw in there. Will take a light in there soon to see. Feels to me to be different inside the housing though .
i have one of these also and the guts are inferior to the OEM unit.
It works fine, for the price you can't complain.
The aftermarket one uses a generic, universal motor. It isn't compatible w/ the OEM one.
Is it possible to order just the OEM mirror? (Just the actual mirror, not the entire assembly)
