replace the master cylinder and?
i have read the posts and done the simple tests and its time to replace the master cylinder. i have been told to order the hose that goes to the brake booster as well (from the motor) is there anything else i *should* so while i am at it?
calling c-dan tomorrow...
If it's a NE truck, check for corrosion around the fittings that go from the MC to the ABS actuator. Good time to get new ones of these as well. Brake lines from Dan are reasonably cheap. Also, check the 3-way T underneath the MC to see if any corrosion has occured there. That piece is about $20 or so from Dan.
Good luck.
-o-
Have'nt heard anybody complain about replacing their stock bleeders with "speed bleeders".
They are on my list next time I work on my brakes. (there are 4 for the wheel calipers and one [slightly diff size] for the LSPV)
Good luck.
-o-
thanks... sounds reasonable.
i did this when i was chasing the soft brake pedal so i am all set here... even the LSPV :D
just replaced the MC. bench bled it til there were no visible bubbles. installed it, bled it at the MC, then the LSPV then drivers rear, pass rear, pass front and drivers front...
still feels soft. i still think it is the LSPV not being properly adjusted and therefor i am not getting help from the rears. this came after the 4" list and extended brake lines.
does anyone have the exploded view of the mechanism that connects the LSPV arm to the rear axle?
Try bleeding the dist. block on top of the fender by cracking the line on top of the block that comes from the top/end of the brake master (it has a loop in it) I had air trapped there after I let the front half of the master get low on fluid and sucked air.
I also used about 1.5 liters of fluid to get my pedal back, after bleeding the whole system 3 times.
Are your pads new?
Your calipers hold alot of fluid when your pads are worn-out and putting new pads in and pushing the old fluid and air back into the system before bleeding might save you some grief.
good luck.
If that's the block near the ABS, I'm not sure if that's a great idea. I've been told that cracking any of the lines near the ABS is asking for trouble. But I don't know for sure.
When I had my brake problems early last year, I went through the following....
Pedal was soft when I purchase the vehicle used. Shoddy Midas break work was recently done by PO.
I bled and bled and bled like crazy and could never fix the problem. Eventually took it to a dealer who was able to bled it somehow with much better results but still not perfect. The dealer did some kind of adjustment between the master cylinder and pedle which was a great improvement.
I noticed a significant improvement in feel when I removed the PO's aftermarket front and rear pads and replaced with OEM Toyota pads.
Now it's about 80-90% of where I expect it to be. I figure eventually, I'll swap rotors to OEM, as I think they are aftermarket as well and the calipers are definately aftermarket and I'll considering replacing those.
I think going OEM with the Toyota LC80 brake system is key. It's not always critical on all cars, but for some reason it seems to make a major different on these rigs. Beyond that, these rigs apparnetly require more bleeding than a normal pumping the pedal that you can get away with on other rigs. If you don't have a power bleeder, you may be better off having a mechanic or dealer or someone who can bleed the rig with a machine.
i wonder what that was?
also, i can look at installing new front OEM pads but the rear brakes are all new less than 10k miles ago.
does no one think its proper LSPV adjustment after a 4" lift install? :confused:
This will only increase pedal effort. You told me that if you held your foot on the pedal it would slowly go to the floor. Has that been resolved?
I remember posting what I did for the LSPV adjustment for you in another thread.
the pedal still goes in somewhat when i hold it there... should it be rock solid?
yes you did post what you did. good point, the whole thing is rusted solid. i need to get a new part where it connects to the rear axle.
i wonder if the guy that installed the SS extended brake lines did it incorrectly and they leak ever so slightly?
my pedal is not rock solid at first, but firms up nicely. What i did for the LSPV took 1 trip to Home depot and about an hours work. Has anyone adjusted the LSPV?
never been done. when randy installed the OME lift it was frozen with rust then. i think this is my next step. that and new pads, thats easy.
