Do you really need to change synthetic line every 12 months?
WARN Spydura synthetic rope is a high-tech, lightweight, easy-to-handle alternative to steel rope. Made from ultra high molecular weight polyethylene, it's coated with black urethane for increased UV and chemical resistance. It includes a high-temperature-resistant sleeve on the first layer, and a unique self-tightening rope attachment to hold the rope securely on the winch drum. Additionally, the rope has a ballistic nylon sliding sleeve to provide extra protection against abrasion and wear.
FMKV said:Do you really need to change synthetic line every 12 months?
For winches with 9,500 lb. (4310 kg) pull rating or less (excludes M8274-50)
Inspect the wire rope before and after each winching operation. When damaged, replace with the size specified in the Replacement Parts List, or go to the Warn website at Warn Industries - Winches, Mounting Systems, Accessories, Hubs, Air Compressors, Flares, Lights, Body Amor.
Just a bit of clarification here:
The first link to the winch rope you posted above (Warn Industries - Winch Rope for Jeep, Truck & SUV Winches: Synthetic Winch Rope) is not the rope that is on the VR winches. This is our soon-to-be-discontinued rope, not the Spydura rope that comes with our new winches. The rope on the VR8000-s, VR10000-s, 9.5cti-s, 9.5xp-s, and M8000-s is rated to pull 10,000.
- Andy
so the new rope just needs inspection every now and then and not to be replaced every 12 months? I just bought the vr10000s.
