replace exhaust pipe studs with bolts?
Discussion in '40- & 55-Series Tech' started by chaka, Mar 1, 2007.
  1. chaka
    chaka
    195
    Apr 16, 2003
    Washington DC
    Has anyone replaced the exhaust manifold studs with bolts? if so, any particular kind/rating? any pros/cons that I should think about?
  2. Coolerman
    Coolerman SILVER Star
    6,124
    Media:
    2
    Albums:
    1
    1,050
    Jan 5, 2004
    Paint Lick, KY
    Cons: You can't hang the manifold and intake from the studs while installing making it harder, If the bolt gets stuck in the head you more than likely will snap it off in the head. Studs allow you to use brass nuts, if the nut freezes to the stud you can easily just strip it off without harming the studs.
    Pros: Bolts are cheaper otherwise I can't think of any...
  3. mr_manny
    mr_manny
    1,655
    12
    Apr 10, 2004
    san pancho, ca
    Only recently found out about running brass nuts...exhaust guy said it was the only way to fly :D
  4. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    And don't forget the anti-sieze:D
    Ed
  5. Coolerman
    6,124
    Media:
    2
    Albums:
    1
    1,050
    Jan 5, 2004
    Paint Lick, KY
    Yep, I had the local machine shop tell me about this trick when I had a set Ford 360 heads freshened. While removing the exhaust I had broken off 3 bolts in the head! Two I was able to fix but they had to get the third one out. When I went to pick them up the guy had a set of hardened studs, brass nuts and washers in a bag. All for $10 extra. He explained he did not want to extract any more broken bolts and to tell everyone I knew about this. :lol:
    So you've been told! :grinpimp:
  6. Hobbs
    Hobbs
    477
    10
    Nov 13, 2005
    Big Pine, CA.
    I like it! I am currently reworking a manifold set and will give this a try.
  7. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    Just one word about brass nuts....................do not over-torque them.:doh:
    Ed
  8. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
    I just installed my rams horns with Grade 8 bolts. It was a cake walk. In terms of removing the "studs" they're a PITA to remove. I had three studs on the bottom that were stuck in the RAMS. I tried to remove those faukers but they would not budge (heated with a torch).
    I gave up and took them to the machine shop and it took them an hour to remove. I asked the machine shop guy (Edwards Engines) about bolts in the mainiafold and he said it would be okay as long as they are grade 8.---so I have bolts in my Rams horns. I hope there won't be problems.
  9. Rocinante
    Rocinante
    90
    Jan 11, 2007
    Wisconsin
    Cool tip, haven't heard of that before. Are metric nuts easy to come by?
  10. Coolerman
    6,124
    Media:
    2
    Albums:
    1
    1,050
    Jan 5, 2004
    Paint Lick, KY
    Nah, easy to find, just castrate a few monkeys from Europe! :grinpimp:
  11. Rocinante
    Rocinante
    90
    Jan 11, 2007
    Wisconsin
    I was waiting for some wise arse to say something ;)
  12. Coolerman
    6,124
    Media:
    2
    Albums:
    1
    1,050
    Jan 5, 2004
    Paint Lick, KY
  13. Brian in Oregon
    Brian in Oregon
    3,040
    9
    Dec 17, 2005
    I've run studs and brass nuts on various exhaust manifolds. Also use spring lockwashers instead of split lockwashers, as they don't dig into the nut.
    Sometimes brass lockwashers aren't the best, though. Some headers can require a fair amount of torque to properly seal, even with thicker "header" gaskets. You can strip out the brass nuts. In this case, I use regular nuts with anti-seize, and once a year remove each nut and retorque it to ensure it won't stick.
