repair quote today
Midland, TX
cruiser has been making some loud noises lately... when you turn her on there a huge roar and then when you hit the accelerator its there again... coming from the front right of the car. so im thinking alright header, exhaust... something like that.
guy calls me today and says an O2 sensor blew out and to replace it and the rework the threads its gonna be $600. which includes an ebrake tightening ... any thoughts? i was kinda caught off guard and have no idea how much something like this would cost. thanks for the help
also im gonna put on a hitch... i can just go to uhaul and pick one up right? they are pretty universal? thanks again guys (and girls?)
Not sure about the fix,which sounds way overpriced, but Uhaul might carry the hitch for your Cruiser. I bought a second hand one off the forum, they come up every once in a while, and had UHaul install it for me for pretty cheap from what I remember.
Have you crawled under there and looked around for yourself?
And I am not sure what tightening the e-brake has to do with the O2 sensor, but it sounds like the mechanic maybe taking you for a ride.
Just my thoughts.
Russ,
Armchair advice = "guy" has seen your "S" insignia on your chest/avatar and is thinking what the heck - Russ is the man of $teel - why not tell him it is 6 bills to insert the popped O2 senosr and throw on 2 nuts (who cares if their the right threads or not... I'll warrentee my work for 15 days!)
Um...here's what I really think....I have a '94 and I've popped an O2 sensor before...When I did it I cut out some extra unused wiring from some defunct accessory light and used that to tie (lots of wraps - I'd bet there's an offical boy scout type term for the the way that I secured and stabalized the loose o2 sensor back into place for the trip home....Yes the wiriig I used was insulated and the insulation burned off with a nice burning plastic aroma - so what? I got the rig home and was able to literally replace 2 nuts on the studs for the O2 sensor for a more permanent fix... for about 3$.
There's no moral but if there was one it would be: If some "guy" says he'll fix your rig for $600....
1) kick him in the nuts and go directly to Mud for alternatives, or
2) see 1) above.
3) based on your location and vintage ('94) your ebrake components are likely due for some attention - I hesitate to reccomend your "guy" - the parts are cheap and the work is rewarding - get the FSM and do it yourself if you can.
best, Rob
good luck and kind regards
I just put a hitch on my 62 yesterday. I paid $215 for a draw tite from hitchfinder it took about an hour and half to put on and couldn't have been easier. I still have to run the wiring, but I've done that a time or two and will only take 20-30 minutes.
beautiful... thanks boys.
haha... ill try and remember the assaulting kick to the nuts after i have my truck keys back in my hands. and then ill have to find a new "guy"/mechanic. how much was the new o2 sensor?... cause mine blew out and is gone. like on a road somewhere...
the ebrake was a seperate fix and turns out it was frozen....?
what class hitch did you guys put on your cruisers?
Class IV hitch? whats the cruiser rated up to towing lbs wise? thanks
Hey RussBow did you check out the classified here on mud. I was there yesterday and saw quite a few. I would sell you mine but it is in seattle. I just might us it as an anchor for my boat.
You might find one close to you and you could buy yourself a christmas present with the dough you save.
5000 pounds. class 3 i think.
check the classified here. i bet someone might be willing to sell their factory "valley" hitch.
as for the price, how much for each part? an ebrake fix can get costly.
the O2 sensor should be ~100 bucks.
check cdan, but also check Auto Parts Fast at RockAuto
some folks have had bad luck, but autozone bosch o2 sensors have been ok for others.
I would think with the O2 sensor out you should have had a check engine light?
Definitely sounds like a hole in the exhaust.
The price sounds high, but...the OEM sensor is going to cost your guy $150, new bung, welding bolting it all down, will take a couple of hours. It isn't that far out of line, especially if he's doing the right thing and replacing both o2 sensors at once.
You can do it youself, but the hardware on the o2 sensors is a pain to deal with because it gets all rusty and corroded. The fact that you had a huge noise and had not even looked for the problem suggests to me that you should let your guy just do it. If you're worried, get an estimate at the Toyota dealer.
yeah ive had a check engine light since forever... i bought the car way back in '00... when she only had 32k miles haha now were at 194k yikes.
i get it checked every so often to make sure its nothing new but its always just been the inner seals in the engine going needing to be replaced and to take apart the engine replace the seals and put it back together costs more than the cruiser is worth so ive just been ridin it out... until the noise started on the nj turnpike haha
no holes in the exhaust... i did check it out when i was changing the oil right before i brought her into the shop last saturday. my "guy"/mechanic took a look too and said definitely no holes or potential rust holes either. we'll see what emissions says the next time i have to get that checked.
the bosch parts ive seen... theres one for $60 (universal) and one for $170 (original equipment) so i'm good with the part and labor. ill make sure hes doing both sensors at once though, nice call... thanks boss
Did you look to see if perhaps the manifold nuts loosend up on you. This happened on my 94' Toyota pickup a couple years back. It was where the manifold bolts up to the down pipe. Worth a look. Good luck.
To avoid future problems you should use Toyota O2 sensors.
-B-
Sorry I wasn't clear--blown out o2 sensor = big hole in the exhaust!
Sorry, but don't waste your time with generic o2 sensors. Your OEM sensors lasted 194k miles. that's extremely good.
What codes is your computer showing? To my knowledge, none of them suggest the replacement of internal engine gaskets. You should have an o2 sensor code, probably the EGR temp code and maybe others.
-B-
not doubting you... but just for my knowledge... why? cause the ecu is calibrated to the toyota O2's?
i like that quote in the sig too
No, just that the impression here is that OEM is always better than aftermarket.
It is all based on the individuals own experiences.
I have used both, and for some things I go OEM, for others I go aftermarket.
i like it.
cruiserdrew - ill get you those codes when i get home from work sorry i didnt see that post before.... stare at a computer screen long enough and stuff starts to melt together.
something else that happened the other day... my ignition eats my key sometimes and i have to jiggle it for a good while before it'll let go of my key haha... anybody else have this happen??
Actually, this is not completely correct. The impression here that OEM is always better is based on reading thousands of posts and listening to dozens of sob stories where someone bought some aftermarket part and subsequently deeply regretted that decision. This scenario has been repeated over and over again during the past 7 years of reading 80-Series posts here on 'Mud and other forums.
In fact, I have no individual experience on O2 sensors other than those on my 175k vehicle held up for 11 years and a lot of miles. There is a recent thread where a guy bought a pair of Bosch sensors and soon thereafter began throwing codes. He exchanged them under the "lifetime" warranty and a few days/weeks later he started throwing codes again. He posted his sob story and several others responded with exactly the same story... premature failure of aftermarket O2 sensors.
For my time and money, it is simply not worth trying to save $50 and gamble that I will get Toyota quality and service from an O2 sensor manufactured by some company in China or who knows where.
Now this doesn't mean that everything on my truck is Toyota because I am running "Green Stuff" brake pads on the recommendation of several, including Tools. I have many other non-Toyota bits and pieces and probably some other replacement parts though I cannot recall which ones are Toyota and which ones are non-Toyota.
-B-
Great explanation Beowulf!
I bought my 94 cruiser about two months ago. It had some hesitation issues but not all the time. It was not throwing any codes. Turned out to be the O2 sensors. They were aftermarket and apparentely worked when they wanted too. Not very old either, based on the amount of rust on the bolts. Removed them and replaced with OEM. Smooth sailing now.
