removing the center consul????
extremetoy1 said:
dont forget you will need to remve the heater core under the passenger seat too, the hoses underneath the cruiser at the passenger side are a bitch to get off!!
i am not going to do that good of a job :D
I mainly want to get what i can get done in a day but how do i get the consul off? are there screws? does it pop off?
i found it... 4 screws.
In the bottom of the lower console there are four bolts IIRC. before you takes those out there are four screws that hold the plastic cover over the shifter. It might take 10 minutes max to get both parts off.
peepers said:
I want to remove the center consul and carpet so i can get some Dynamat down. How do i remove it?
This is on my list of "to do's". Post back your thoughts on the inprovement(s).
thanks for the tip. i got the back done. removed the rear carpet, covered the rear deck and the wheel wells and under the rear seats. a good bit of difference sure. worth all that $$$$$ for the dynamat extreme? NO. i will keep you posted to see how the front makes a difference.
Hey how was it to get the carpet up? I am thinking about swaping adding the factory locking diff harness. I have the factory location diagram and it looks like you need to pull f/r drivers side seats and the center console.
Did you happen to take any picture of what you saw under the carpet?
i never did get the front carpet up ... but i will be and when i do i will let you know... i will take pics.
