Removing the 3FE air pump bracket?
Huntsville, AL
I'm in the process of removing my emissions stuff, and took off the whole PAIR/smog system except for the injection tubes.
I removed the bracket that the air pump mounts to, but later realized that this bracket is attached to the motor via the #11 and #13 head bolts. Well, my thought process was "why does it take an 8 inch bolt to attach such a small bracket.... Oh crap!" So, I've reluctantly reinstalled the bracket.
Is there a easy/common way of removing this thing? My choices (from least desired to most) are:
  1. Leave it on
  2. Grind it down as small as possible
  3. Space the head bolts with washers etc. to get the right amount of thickness
  4. Use shorter head bolts
  5. Buy a ready-made "delete bracket" with just enough material to reattach the engine lifting hook.
This bracket is an eyesore, and worse blocks access to the cold start thermo switch and alternator. Plus it's dead weight. Has anyone messed with this before?
I think you can remove part of it. I desmogged a couple of years ago and don't exactly remember. I have great access to the alternator now. I'm interested to hear what you find out on removing the rest.
Cheers,
Scot
I can't tell from your picture, but mine has a "tab" that covers up what looks like a thermostat bypass hose and keeps me from getting a socket over three of the sensors.
Some people might like their engine to have an appendix, but I have no need for one.
Lots of folks have pulled just enough head bolts to remove/replace engine hooks with no ill effects, including me. Stack enough washers back on the bolt to compensate for the thickness of the missing bracket material and torque them back down.
I may try that, or get a spare bracket and grind it down. I just wanted to see if anyone else solved this problem before me.
Weird. I don't remember this bracket when I desmogged my 92...
I'll look when I get home.
Mine is a California edition, so I'm sure they made everything more complicated than it should be.
There was only one emissions set up on the 91-92...
I just checked my 92. I have that bracket. It must bother me so much that I didn't remove it or realize I even had it. :smokin:
Yes I have that tab. Guess it doesn't bother me too much.
Cheers,
Scot
@mct75 I don't recall... I removed EVERYTHING that was related to the air pump, egr, the rail thing, exhaust pipe, etc.
I haven't thrown a CEL since I did the delete.
If you're super bored can you take a look at your EGR temp sensor wire? Supposedly non-california trucks had a shorting plug connected to the lead for it, which prevents code 71. I'm too scared to short mine together without knowing though. I'd hate to burn out the ECU.
Which one is it? Got a pic? I'll run out and check.
I doubt non California vehicles had this jumper but I will check.
It's the gray connector right in the middle
It sure does have a jumper!
Wonderful! I was 90% sure that's what Toyota did but didn't want to risk it. Thanks so much!
While we're at it, do you know what the other wire is in your picture? It just seems to connect to the intake manifold. Is it some sort of ground?
