Removing stuff; help
SoCal
The brake switch. Oh, 74FJ40. The plunger end of the switch is contained inside a threaded tube. To emove the switch do you just back it out by rotating the whole switch? I started to but part of the support under the dash interferred with getting it all the way out. My eyes suck so bad I couldn't tell if the switch came apart or should be taken out some other way.
Two. Is there a tool available to unscrew the round nut that holds various dash switches in place? They have a couple holes in them and I know there must be some kind of tool made to insert into the holes to turn 'em loose or tighten.
Thanks for the guidance. I need it. :-) Well, actually I mostly needed the guidance before I bought this truck almost totally disassembled, but it's too late for that now. Besides, I love puzzles and I've always wanted a 40.
Happy whatever day it is tomorrow that allows me to stay home and be puzzled some more.
Vic
Redlands, CA.
On the brake light switch--the whole thing comes out, including a wiring pigtail about 6" long. On the threaded section there will be a lock nut which, if my memory is correct, will take a 14mm wrench. Tight quarters? YES!!! ( the voice of experience ) I now have the dash panel out and if I have to replace the brakelight switch again it looks like it would be a lot easier that way. Good luck!
The way I get those round nuts off is to reach up under the dash and twist whatever they hold while holding the nut by hand or maybe with small waterpumps. Just enough to loosen it then take it off from loose.
3DAMAN! said:
Try using a good quality set of snap ring pliars
X2
Works great EVERY time.
On the brake light switch...
I have found some of them to be a bit difficult as you have described, but they can be persuaded...
Good luck!
-Steve
Vic, it sounds like the tech has been covered. So let's get on to the entertainment.
In Vic's own words "When I was offered the cruiser, I said 'What the heck; I haven't done anything stupid in a while!"
