May not be hardcore, but this is not specific to a certain vehicle so figured I'd put it here.
I have the Dakar CS004 packs on the back of my fj60 that I chopped down into a "pickup". It rides like s*** now and has a terrible shackle angle since I took maybe 500 lbs off the back of it. First thing I want to do is remove a leaf or two and see if I can get it riding better before messing with spring/shackle mounts.
Does anyone know how many leaves I can safely remove from the Dakar pack? I'm definitely ditching the long AAL that makes this a "heavy" pack. I'm wondering if I should remove one of the shorter leaves as well. Ideally, I'd like to lose an inch or two of height and some spring rate so the suspension will actually cycle. I've got some stock packs that I can take leaves from if that would be necessary. Pictures below.
Current stance = s***ty.
Pack in factory form. 8 leaves. 2 overloads.
With these leaves in I can jack up the spring and the shackle sits at about 55* when the frame comes off the stand - ie. vehicle weight sitting on spring.
And these are the leaves that are removed in the above picture. Do I need both overload leaves?
