Removing Extra Weight
Since getting the FJ80 not too long ago, I've removed some weight: 3rd row seats, bottom wheel & tire, junk from trunk, etc. I even drained the water that was stuck in the fenders for probably the past 5 years (thanks to the info from this site)! The tank took a LONG piss hahaha. Probably removed close to 200 lbs of weight but not really sure I feel a difference...
Now is the LC a vehicle where removing extra weight doesn't really improve performance due to the low gearing/ low RPM, design etc? I've only used it on-road so maybe the better power/weight ratio will show up better off road, but then again, I see pics of cruisers loaded with lots of heavy extras especially off roading.
200/6000=3%. Not much of a decrease in weight. It's going to take a lot more than 200lbs to have a noticeable effect.
You're driving a tractor that happens to have A/C and a radio, get used to it :meh:
6000 lbs?!? I thought it was 4,800. Damn, if it is 6,000 lbs they should've put in more than 155 hp. Also, my A/C is dead...the radio illumination for the stations comes on & off. But I still get a silly grin driving around in the Tank :D
Since getting the FJ80 not too long ago, I've removed some weight: 3rd row seats, bottom wheel & tire, junk from trunk, etc. I even drained the water that was stuck in the fenders for probably the past 5 years (thanks to the info from this site)! The tank took a LONG **** hahaha. Probably removed close to 200 lbs of weight but not really sure I feel a difference...
Can you point me to the thread about draining water in the fenders? Thank you
x2
I have (most of) the junk out of the cargo area, no 2nd row seats, probably dropped 300 lbs with everything out of it.
Didn't notice a single difference except that when going over speed bumps it bounces a bit more in the rear. :doh:
do you notice a difference driving with one or two 200lb friends in the vehicle? Not so much, but every bit helps I guess.
I am in a similar boat with the 80, cummins 6BT, heavy bumper, 8274, 37's, RTT, still have the third row and got a few tools in the back, soon to be going to a NV4500 and toyota split case instead of the A440f. I should put it on the scale with 5 other people on it...
I should really be going to one ton drive train i guess.
I guess shedding some weight on this Tank doesn't really help with anything. Wonder if the MPG improved at all. Yeah, I'm not driving this thing around to save gas I know, but would like to find simple ways to improve the performance.
The 2nd and 3rd rows probably weigh about 200 pounds. And then the seat belt hardware is probably another 30 pounds, a couple of other things and you're at 300 pounds lost.
Add a fridge, bumper, winch and now you're back to normal. Throw in a fat chick and now you're over-weight.
LOL :lol:! Now does the Landcruiser make a fat chick seem less fat?
I can feel 300lbs on the trail. i can certainly feel when 2 friends are in the truck with me.
on hard shorter trails i leave the spare (way heavy), toolbox (way heavy), rear seat, co2, highlift, shovel, ax, winch (quick disconnect), pair of extra driveshafts, and sometimes the middle seats if im alone. on these trails ill only have a half tank if poss. this exercise takes less 20 minutes and makes a world of differance on difficult trails.
I only do it if the guys im with are good friends and have winches. no need to carry all the gear all the time
I did several solo wheeling trips with my wife and kids last year. 8 mile loop. i have all my gear then and dont do stupid lines. carry heavy weaponry too...dont approach my truck uninvited
I dont do this when Im soloing
FYI, my stock 91 FJ80 scaled out at 4,650 with no driver and half tank of gas. It has all 8 seats and spare tire and jack.
