Removing EGR
80 in Cambodia
Can I remove the EGR and some of its vacuum controls to set my motor up like the non EGR equipped middle eastern 80's.
Or will the throw code's .
Napa sells the valves but list two of them from 1/95 and one to 1/95
Any one know what the diffarance is? I can't go a look at my build date im parked 10000 miles away.
Im going to block it off or just keep spending $$ on fixing it.
Any thing I should know about removing it to replace or block off.
Bolts that will bust off rusted parts stuck hoses?
I did have pinging at part throttle and I had the code 401 I did replace the valve that comtrols the EGR.
I still get the code and the pinging . So do i need the EGR to work?
also do i have OB1 or OB2 in a 1995?
I need to pick up parts in the states and bring them to Cambodia.
Thanks
I've removed the EGR valve and made a backing plate for it on the head as well as the throttle body. Search under my name and "Rust belt rebuild" and you'll see how I approached the problem.
You will throw a P0401 since there is no EGR valve anymore, but you can bypass this with a resistor in the EGR temp. sensor.
Good luck.
-o-
This is something I want to do also, only thing i need are the block off plates. I went through you whole thread, all the way to the last page where i finally found the part pertaining to this....lol
I see you fabbed up the plates your self, any interest on making a few extras, i bet there is a small demand for them. :grinpimp:
