Removing EGR mounting bolt
Portland, OR
Website
bsky.app
EDIT: meant to say removing the *stud*
Diving into cleaning the throttle body, upper intake and injectors today. Unfortunately rounded off the end of one of the bolts on the EGR mount that connects to upper intake; since I was going to have to trash it to get it out, I dremeled a screwdriver slot into it but the metal is soft and bolt still not budging. Soaking in PB Blaster now.
Any other suggestions for getting this out so I can move on to cleaning and buttoning it all back up?
Are you're talking about the 2 STUDS with nuts?
The studs can be removed with a female star socket, though often when removing the nuts the stud will come out.
Have your tried to remove the nuts on the studs??
cheers,
george.
I'm sorry- I do mean the studs. I used a female star socket on one only after trying to shortcut w a 5mm socket on the first. Didn't work for me.
The nuts came off the studs fine w no issues.
cheers,
george.
EDIT: double nut for the win. Thanks--it worked. I'm new to this. Onward...
I'm currently in the same situation. I have one bolt removed but cannot get the other loose. I've tried sockets, the double nut method and a vice grip . I think the double nut would work, but i can BARELY get the second nut threaded and it just won't hold. Any thoughts?
