removing door panel - mirror cover
Any trick to removing the side mirror cover? I can't seem to pry it off. Manual doesnt give any detail.
Ignore the dirty cruiser...... spent last weekend camping :)
It has a Pin thingy just past half way up. You have to pry it out. You will likely break it. I have broken three and I got weedled off and drilled a hole through the last one and put a counter-sunk screw in it and a well nut in the hole in the door.
I'm not in the office today but IIRC it's about 16 bucks or so. I'll go take a pic of what I did to mine.
Thanks Dan. And thanks for getting me the glass run (or whatever it is called) here so quickly.
Does anyone know if I need to remove this cover to remove the inside door panel?
I have all of the clips on the sides and bottom removed but something is holding it at the top. Any ideas?
Yes, it has to come off to get the trim panel off.
Here is what I did with the last broken one:
When I read this I had just taken mine off and was proud I didnt break it :D
I put it in the center console with all my crap for work .
I couldnt find it a couple of days ago and figured It was hiding somewhere in the truck . I found it this morning in the driveway, run over with a nice MT track across it . :confused:
I must have kicked out onto the driveway one night then ran it over "awe :censor: " i said :doh:
Well so much for getting it off in one piece :mad:
Just called Cdan to add it to the list goodies I ordered a few days ago that hadnt gone out yet :cool:
Someones got to help Cdan feed the dogs so they dont bite him again :D
I found this thread in the archives this weekend when I was busy replacing the belt trim pc's in the top outsides of both front doors - I needed to remove the mirror as well and that triangular shaped pc of trim needed to come out.
I used an old credit card as scratch protection and a door trim tool - kind of a a combination of a screwdriver and a fork w some usefull bends for prying - to get the triangular trim pc to come unlatched. As CDan says, there is a pin and socket joint in the top third of the pc that has to come out. In addition, there are a pr of plastic catches in the bottom of the triangular pc that hold the bottom in place. The pin and socket have to be removed partway before the bottom pr of catches can move - then it kind of swings out with the bottom catches acting like a hinge.
The trim tool is the thing I found that could get in there to apply the prying force without breacking the plastic. Find a trim tool that is as slender as possible while still strong enough to pry with. Use the old credit card first to help locate the pin and socket joint and then move the fork of the trim tool in and aorund the pin. Then pry towards the interior of the 80 and it should pop out. I helps to roll the windows down to get a better view underneath the triangular trim pc.
Phil
'97 40th w stuff
San Jose, CA
No, it doesn't.
Once the door panel is free except for the top, you can wiggle and lift the rear part first, then the whole thing slides back a bit and out. It's easy if you know it can be done...
To get the plastic cover off without breaking the pin off, use a medium-sized slotted screwdriver 2/3 of the way up the cover and be sure the force you're applying is perfectly perpendicular to the door. If you're twisting then you'll break it for sure.
:banana:
Nothing related to the tech of this thread, but has anyone seen "Lars" lately?
He was a hell of a good contributer to MUD and then all of a sudden he just stopped posting...
Anyone konw who he really is? Location?
I always get worried when MUDDERS who are good contributers just disappear....
Thanks.
-o-
