Remove hood for windshield?
St. Louis
Getting ready to have my windshield replaced and we're going to follow the FSM as recommended. After reading all of the threads, I'm still wondering if and why you would really need to remove the hood as the FSM says. Can I skip that step?
Haven't done it myself, but that is recommended. I think more to get it out of the way so you can get at the bottom edge of the windshield to clean, etc.
That said, I'm pretty sure the pros who did mine did not remove the hood. YMMV here. If they're pros, this is one area where deviation from the FSM seems reasonable, so long as they back their work in case of a leak. If it looks good and easy enough to clean, etc if you DIY, I could see skipping it. But if there's rust, etc that needs attention might be better to still pull the hood to get at it good.
You can do it without removing too much but if I was doing it myself I would remove wiper arms and the metal air inlet valence.
I don't see why you need to remove it if you have a short enough phillips. the cowl is there which probably should be removed to ensure a good seal is made.
