I finally got my transmission temp gauge hooked up and found that, yeah, my transmission has been a little hotter than I would like. I used to have a huge 12"x12" aux cooler in front of the A/C condensor but in really hot weather it blocked too much air flow. I replace it with a heat sink cooler behind the front bumper as a stop gap but once I got the temp gauge hooked up I found I needed more cooling.
[As a side note my transmission has been rebuilt and I'm running one of Rodney's Extreme valvebodies with 3rd gear lockup. I can't imagine how hot the transmission must get pulling mountain passes in 3rd gear on a hot summer day. I saw 240 degrees return temp (measured after the stock in radiator cooler and heat sink cooler) in 3rd pulling highway 2/Stevens pass here in Washington in the middle of winter. As soon as I hit lockup in 3rd the temps dropped down a lot but with traffic moving at 40-45mph I was just below lockup speed for most of it.]
Anyway I decided to go with a B&M remote cooler with fan (Summit Racing: B&M 70298 - B&M Hi-Tek SuperCoolers with Fans - summitracing.com) and to mount it under the passanger floorboard outside of the frame.
My biggest question was how to plumb it in. The stock flex line fittings are 16/1.5mm straight thread with an "inverted" flare. The question is what is the angle of the flare. I picked up a Gates female 16x1.5mm inverted flare to 3/8 hose barb fitting at my local industrial hose shop (part # 730308215). I'm still not sure what the angle of the flare fitting is and I couldn't tell if this part matches the stock angle or not by looking at them side by side (they look the same to my eyes). Anyway I've down a couple of test drives and no leaks from this fitting.
I used regular 3/8" hose barb and worm clamps throughout with transmission cooler rubber hose (covered with Russel's braided split loom). This works fine, no leaks. I might switch to AN fittings and SS hose at some point just to clean up some of the hose routing that I did to avoid sharp bends.
Pics next post.
Pics next post.
