Hey All,
I just bought a 2000 land cruiser that has Slee reservoir shocks in the front and rear. The truck is running 33" tires (255/85R16) on the factory wheels. Rear has Slee heavy duty springs and the front has cranked factory t-bars & Total chaos UCAs. My issue is that the remote reservoir rubs at full lock. The P/O mounted the shock reservoir on some brackets under the frame rail (see photos) which seems to work fine except for the rub. I looked into the Slee installation instructions and noted that they recommend mounting them further up on the frame. I fabbed a little bracket and attempted to move the reservoir up to that location but that put a LOT of strain on the hose; i was really unable to position the reservoir appropriately on the truck without fear of damaging/kinking the hose. I reached out to Slee and they basically confirmed the recommended location but I cant get it to sit right. Initially i thought that the hose was "wrapping" up and causing the bind but It seems like the hose is just a few inches too long. I was able to relocate the passenger side reservoir up further into the wheel well, but even then its a little close for comfort. The drivers side doesn't have any additional room to relocate the reservoir into; so I left it where it was under the frame. At some point im looking to switch to wider tires (285/75R16) and am concerned that the problem will get worse.
Any thoughts on what to do next? I want to keep running these shocks if possible (might send them out to get rebuilt) but I'm worried that rebuilding wont change anything (slee seemed to think that it might). I did notice that my reservoir has a 90 degree elbow at the top whereas the ones pictured on the website come straight out.
I also thought about running spacers (slee spidertrax, 1.25") which i think will solve the issue, but honestly i would prefer not to run spacers to avoid the hassle (and any potential safety risks). If this is the best/only option ill go this route. It seems like folks running other remote reservoirs all have rubbing issues with 33" tires and maybe this is the only good solution.
Where the PO mounted the shock: (you can see rubbing on the rear portion of the reservoir by where the hose connects)
The recommended location - note the strain on the hose
