Regulator Drawing amps
Gainesvegas, Ga.
I am trying to track down what is causing my battery to drain. When the engine is off there are 3 amps coming out of my alternater through my regulator. The Alt and reg are both new. I have rewired with a Painless system. The alternator is working when the engin is running. There is 12 volts coming from the fuse block to the regulator, and I do not think that is ment to happen(this occures when the engine is off. Could I have hooked the wrong wire to the reg?
It was coded to go to the regulator excitor.
It could be wired incorrectly. The regulator and field coil of the alternator should only be hot when the key is on. Try pulling fuses individually and see if the that stops the drain. The regulator is supposed to get power from the engine fuse, which is only hot with the key on.
