Thanks. I'll weigh my options when I have some more info.
This is a simple middle school math problem. Stock rpms at a given speed * 4.88/4.1 * 31/34. 80mph is approximately 2600rpms. Very smooth and chill for the 4.7What's the recommendation for a 5-speed running 34" tires? Are 4.88s going to have me buzzing like crazy and topped out at 70 MPH?
I think either the wording or my reading of your first sentence is a little funny. You're saying if I'm going with an aftermarket locker set up, then DO get the non-OE-locker option?
I am likely leaning toward the Harrop e-lockers, so just being sure getting a gear kit for "no e-locker" won't hamper that install.
Yup, sounds more like a tractor now...but my radio is still louder, so no big dealDo you notice any gear whine with the new Tcase gears?
I would agree with you as well (with zero data, but just some logic) that the forces have to go somewhere right. Like say a rear tire of a bike, and the gears are still attached to the hub in exactly the same spot, no matter the reductive gear you choose. You feel less strain, and the wheel is able to be moved at higher loads, but the hub will see proportional stress increases with load increases.What a stylish response. However, it is your argument that isn't true, as five minutes of research would show you. Just one authoritative example here, from one of the largest aftermarket suppliers of differentials. Go read it and then perhaps rethink your attitude. Regearing a differential to a higher numerical ratio weakens it, period. As I mentioned, there is sufficient leeway in the strength of most differentials to allow such modifications if you don't go overboard; nevertheless, you are compromising the strength of the unit. When combined with the extra stress of larger and heavier tires, the effect is exacerbated.
have any of y'all that regeared, done with a thicker oil now? I am using full synth 75/90.
