red light on dash?
While out driving my 74 fj40 a red light on the dash came on. The light goes off when I press the brake pedal. I checked all the fluid levels and they were fine. It ran great all day (even after the light came on). The light is all by itself just right of the instrument cluster. In the year I've had the rig this light has never come on. What is this light for and should I be concerned.
Thanks.
That is your brake system warning light. When you say you checked all fluids, did you check your brake master cylinder? Typically, it means you are low on brake fluid.
Good luck!
I checked the brake fluid levels periodically throughout the day and they were always full. The brakes worked perfect all day. I'm wondering if maybe it could be a bad sensor?
Thanks!
the light stays on with the e-brake handle completely depressed, but when I wiggle the e-brake handle the light goes on and off. So I guess I'll check the e-brake switch then check the rear brake adjustment.
Thanks
