red beard
so the day has come….ive handed over the keys. my 17 year old has been working beside me since we bought this with the intent it would be his to drive. he’s been driving it off and on this past year when it had a roof but always on back roads and light traffic. today he gets to start to figure it out in traffic. he’s a great driver and properly cautious so he’ll be fine.
i’ll have to drive it now and again to get my 40 fix while mine is still in pieces. i looked at it today at least
well the cheap foil backed foam under the headliner didn’t stick and the headliner fell off. oh well. it was worth the try. i’ll have to take the off again later and redo it.
on a different note im having troubles with signal lights. seems like the flasher doesn’t want to work. i can tap the flasher and it’ll signal for a few blinks and then stop. are these flashers specific to my fj40 or will any old flasher work?
Check the inside of the contacts on the bulb holder, the center button and the holder itself plus the bulb and the grounds. Pencil eraser is good for cleaning the contact buttons. Q-tip with dielectric grease will help with corrosion.
still searching for the electrical issues. no joy. i did find that a PO used some trailer wire plugged up under the dash so we’re going to try and make that a better job.
with winter coming though i need to get door seals done. i did some of them a while ago but didnt prep it right and didnt glue it right so they didnt stick. live and learn. the adhesive is supposed to be used like a contact cement and not just a glue. i guess i should have read the instructions. i’m also trying to clean all them oxidation off the paint this time too to get a better bond. so here’s door number one getting cleaned up again
i’m making the assumption it’s good as i have city racer seals and 3m weatherstrip adhesive. but i’ll double check.
edit. i have 3m waiting for my chevelle. i have permatex 81850. it’s apparently not a good adhesive for city racer seals!! crap. glad i haven’t put more on than just the rear lower hatch!!
It is my understanding that there can be adhesion problems if the glue isn't specific for the type of material used in the seal. You might want to verify that your adhesive is correct for your seals.
City Racer guidance here on materials and adhesive:
thanks for this!! my chevelle weather strip is also precision brand made from epdm rubber. my 3m super black won’t work on it either. you’ve just saved me a lot of headache.
yeah i’ve cleaned the seals well. my 3m is the 08008 stuff city racer says specifically not to use. it’s the super black. my son is grabbing a tube of the 3m black 4799 right now
i always learn something new on these projects!!
According to the page I linked the 3M Black 08011 is what is needed. The 08008 is for Neoprene rubber.
"AI Overview
The best 3M adhesives for EPDM and neoprene rubber seals depend on the specific material and application:
For EPDM Rubber Seals
    • 3M™ Industrial Adhesive 4799: A brushable, heat- and water-resistant industrial adhesive designed explicitly for EPDM and general rubber sheet seaming or sealing. [1]
    • Note on EPDM: Standard neoprene or general-purpose rubber adhesives (like 3M 1300) explicitly state they should not be applied to EPDM, as EPDM requires specialized chemical formulations like 08011 or 4799 to stick properly. Users on communities like The Jalopy Journal confirm that 08011 vastly outperforms general alternatives like 08008 when bonding EPDM foam rubber. [1, 2, 3, 4]
For Neoprene Rubber Seals
well i havent found the signal light issue but i think ive narrowed it down. i put an LED flasher in and some led bulbs. i now have signal lights and running lights but only one brake light and it seems to be the opposite of the last way i signalled. so theres probably something wrong inside the switch under the dash that brings the wires from the steering column switch and the brake lights.
i also got these hateful tubes installed from the cowl drains!! there is just no room for my fat hands up in there!!
lastly we’re taking the motorbike tail lights off that were used for signals up front and putting a set of 1977 lights i had laying around. the piston was rotten off on both so we rebuilt the bases with a 3d printer and ate making g a secondary slot for the wires to run through. it’s looking pretty good!!
got the lights sorted finally. i took the signal box apart and uncrimped the wire panel. inside are two sets of triangular slides with three contact posts on each. they were running in some well worn grooves when i ran the switch with my fingers all the lights worked so i figured the pressure caused by my fingers probably wasn’t there when it was just hooked up mechanically. so i took the springs out from under the triangle pads and stretched them to make more pressure. sure enough that was all it took. i greased everything up while it was apart. now all the lights worked as they should.
i forgot to take more photos 🤨
under all those wires is the panel that comes off by inscribing 4 corners.
