Recovery loop bolts?
Seattleish
Does anyone know the bolt size/pitch for the 80’s OE recovery loops (where it bolts to the frame in the front)?
If you want to save a few bucks you might want to shop around, plus the ones shown below are fanged just like the bolts used on the factory recovery loops.
BF12X1.25X40YLW - Flange Bolt 10.9 Yellow Zinc [BF12X1.25X40YLW] - $2.03 : Bel-Metric, Metric Hardware, Metric Fasteners, Metric Bolts, Metric Nuts & Time-Sert Thread Repair
Pricing:
$2.03
M12x1.25x40, M12x1.250x40, M12x40, 12mm X 1.25mm X 40mm
Metric JIS 1189 Small Head Hex Flange Bolt
Diameter: 12mm
Pitch: 1.25 Extra Fine Thread
Length: 40mm Full Threaded
Wrench Size: 17mm
Flange Diameter: 24mm
Head Style: Smooth (Non-Indented)
Material: Class 10.9 Steel
Finish: Yellow Zinc Plated
Standard: JIS B1189, JIS B-1189
This JIS Flange Bolt is plated in yellow zinc for a restoration quality finish. Sometimes referred to as "gold" colored finish, yellow zinc chromate plating has largely replaced original yellow cadmium plating previously common to the restoration fastener industry.
Add to Cart:
  • Model: BF12X1.25X40YLW
  • Manufactured by: BM APPROVED MFG
Qty Discounts New Price
1-24
$2.03 25+
$1.29
