Recommendation front driving lights
Dallas, TX
guys,
I am looking for a pair of driving/ fog lights for my arb bumper on my 97 80.
Looking for something small and compact but still very bright. I actually prefer a rectangle shape....
any thoughts?
In reality, round lights offer the most light for the money. The round design spreads the light in the most efficient manner, over a wider area.
That said, after many years of mounting all kinds of lights on a wide variety of off-road machines, I must suggest that the more light that you get for the buck, the better.
I have gone fron lo-tech to high and back again.
There are many lighting companies who will tell you about the advantages of HID or other things, but the proof is in the amount of light that you have where you need it. Really cool lights are great, but they do not prove themselves in the real world.
In the LC world and others, we use the simplest kinds of lighting to illuminate the world around our trucks. Some are using lo-volt home and landscape lights, some use HID.
I suggest that you look at the kind of lights offered by generic producers. Try the plastic housings with glass lenses and H-3 bulbs. Put plenty of them on the truck. They are inexpensive and readily replaceable when you break one of them. Lights are the most often damaged item on any custom truck. Why should they cost a lot?
Off-Road light manufacturers make their products out to be superior, and they are. But they are not superior to blunt candlepower. One pair of high-end lights can put out 500,000 candlepower, but you can only aim them in two directions, and they cost $300. Several pairs of simple lights can put out 600,000 candlepower, and you can aim them in many directions. They may cost as much as $100, and they are disposable. Which is really better?
Since driving and fog are two completely different types of lights you'll have to decide what you want to use them for.
If you've done the HIR and harness upgrades, then you'll have to see if you want whether you want the immediate front of the vehicle lit up for city/foul-weather driving or narrow and further down the road the highway driving.
I think the most common replies you'll get here are either LightForce or Hella Rallye (FF)4000, possibly mixing the driving/spot lense/light patterns. The Hella's are big, but the LF can be had with smaller diameter(s), if you wish.
I personally would prefer something big for the ARB, rather than something small though (Small penis man syndrome.:D)
Good luck!
any recommendations on fog lights? Are the LightForce fogs?
I prefer round reflectors to square because I think they work better, but the end results are negligible. On the ARB you can squeeze in the big Hella 4000s or the gigantic Lightforce 240s, but they really dominate the front end. I bought a set of the Lightforce 170s because they fit the ARB well and won't block all the airflow. I haven't installed them, so I can't report on how they work, but I did a lot of research and they have a great reputation. I have the 170s and Slee harnesses waiting for a spare weekend install...
I have PIAA 520s on there now and they aren't any brighter than my stock highbeams, no point in turning them on.
Once you have powerful, solid lights you get spoiled fast. I had the Hella 4000s on my last truck and absolutely loved them. The broad, flat, metal base design is excellent - no vibrations when driving, and they are adjustable in the field with an allen key. But they need a flat surface to mount to; on my TJM bumper they worked well. They were a little big for the ARB so I sold them with the old truck. I really like the concept of the adjustable beam pattern on the Lightforce because my driving conditions are varied. I'm primarily concerned with long range lighting for higher speed travel, so I want to see the deer, caribou, moose and bear well in advance. I'm usually on remote roads with long sightlines.
The ARB is too high to effectively run fogs. And even though I live in fog central, none of my fogs have ever been effective on my trucks simply due to placement. The only car I had fogs on that worked great was the factory lights in a Subaru Outback, and that is because they sit so low to the ground - they really did a good job. But the ARB is 30+ inches high, so fogs won't do anything but illuminate more fog.
I don't like the disposal light idea, I'd rather have a high-end light and be done with it. Mounting on the ARB means you won't easily damage the lights. Run some clear covers to protect the lens and you'll be set for a very long time.
I like my LightForce 240's. ;) (Spot pattern)
IPF 968s at Costco online (of all places) - $90 shipped.
Do they make a noticeable difference if you're running the Slee harness and HIR bulbs? I have what I think are a comparable pair of old, old Hellas on mine and I can barely notice when they're on with the hi beams.
They come with 100w bulbs and probably a better reflector than your old Hellas, so I'd bet so.
Thanks. I would kinda hope so, really. The Hellas made a difference on my old S-10 Blazer but those headlights really sucked.
