Recommendation for potential purchase
NOLA
Hello - New to the forum here and wanted opinions on a potential purchase of 1991 LC. My son and I are looking for a project car and found a 1991 on craigslist. Its been sitting idle (outside) for 9 years and was last run 5 years ago. The owner says the engine had a "knock" so he just put it his backyard. Plan on going to see it this evening. Only asking $1k. We don't have access to a shop, so we're not looking for a project that would require serious equipment or knowledge, but for that price I'm not sure we could go wrong. Perhaps just use it a parts car if the engine and transmission are shot. Please let me know your thoughts.
GB
If you guys can handle swapping in another engine it might be a good deal. If the body, interior and drivetrain (other than engine) are in good shape all you would need to do is swap in a used 3FE (~$1500). I doubt there is anything wrong with the transmission. Engine swap could be a fun father/son project and you would be in it for under $4000 including "while you are in there" parts.
If you do buy it with the intent of replacing the engine, this is a real good opportunity for wrenching experience and attention to detail. The swap in theory isn't that hard, it just takes time and patience. You have to dis-assemble nearly the WHOLE engine compartment to do it. Of course, doing this means you can clean everything and put it back which means you have a seriously NICE Cruiser when you're done.
FWIW a '91 or '92 is a great place to learn since the engine(OHV with Pushrods) and drivetrain(No Electronics!) is more reliable and easier to work on.
You could also run it for a while with the knock and probably be OK. Just add some beer to the crank case first...
If not run in 5 years do not try to start before getting all water out of everything. Rides that sit outside can present big Issues. If you want to tinker knowing you will replace engine after you do all other needed mechanical work, that Is what I would do. Being able to drive will help Identify what needs attention. Now, I have done this a long time and beware of RUST, you will be breaking things all the time and trucks with bad rust are NOT fun, and Fun is what your looking for. If you want to learn, a rusty truck will teach you that you don't want to do this again. I'm serrious. My son and I have done this together for 30 years, Its the best. MUD Is where you want to ask for help, people here are friendly careing men who want to help. Most of us have seen the issue you may have difficulty with In the future. I hope this works out for you and your son, Its a great Idea. GOOD LUCK..!
So we went to see the LC yesterday and here is what we found…
The car was purchased in about 2004 from the original owner. In 2006 the seats were recovered, new carpet installed, the exterior painted from white to black, and new rims installed. In 2009 the car developed a “knock” and was placed in the owner’s back yard where it is presently. The owner started it once about 5 years ago.
The car appears to be intact with minimal rust on frame. There is some corrosion on parts of the engine; probably just cosmetic. The owner has original rims. Paint was fair would have preferred original white. There were some signs of animals / vines growing in the engine compartment, but did not see any wires chewed or signs of damage. The seats and dashboard are still in good condition. Center console was very worn. Doors closed well and rubber seals around doors were in good shape.
The odometer reads 133k. There was oil in the engine; seemed to be overfilled and clean. The sparkplugs looked clean. Air filter was fairly clean. The radiator looked very rusty and there was no sign coolant. Radiator hoses were dry-rot. We did not try to start the engine.
Our goal is to find a father/son project car. But due to my time constraints it’s more realistically a project for my son with direction from me and others. I could just consider this an engine replacement, but I’m concerned that might be too difficult for my son to make progress without me around. I’d like to spend a couple hours on the weekend with him and have something during the week that he can spend significant time on by himself. He does have two friends with LC’s that I’m sure would provide help if he needed it once and a while.
Option 1 – purchase truck as is ($1,000) tow home and attempt to repair existing engine. If not repairable resell as is. How often is an engine knock repairable? If we resold the car is recouping $1,000 a reasonable expectation? If not, what is?
Option 2 – try to start car prior to purchase and see if “knock” can be diagnosed where it is. We could have our local mechanic join us to help diagnose the issue. Not sure starting the car is a good idea in its current condition. Are there any precautions we should take? The current owner is not concerned about us trying to start it as he’s anticipating selling it for parts. Purchase truck if it appears fixable. The owner wants needs to move the vehicle as he's selling the house and moving away. He does have other folks looking and willing to buy it for parts; don't know what they have offered.
Option 3 – keep looking. We’ve seen local LC’s at about $3k to $6k usually with high miles 200k to 250k. Would you expect we’d spend that kind of money (assuming the engine can be fixed) to make this road worthy? I’m thinking we’d need to at a minimum replace all hoses and fluids.
We really appreciate the wealth of information that’s been accumulated here and thanks in advance for your thoughts.
Offer him $500 and take it home, then worry about whether to sell it for parts. You can part it out (a lot of work) and make $3000 on it. Fully expect to dump $5000 into this truck as it is to make it a DD and that's NOT making it pretty or having accessories like bull bars and winches.
All hoses
Oil seals
Radiator?
Knock?
Fuel issues
After a truck has sat this long with today's crappy fuels, they varnish worse than ever due to some of the additives. Even when you do get this running, it will have fuel related issues.
The knock could be a number of things. It could be a loose crank pulley, it could be someone forgot to put oil in it because it leaked so much, it could be a valve going bad that is causing a noise, or it could be the power steering pump that's not set right or has the wrong fluid in it.
This is a vehicle for a :banana::banana::banana:+ You will definitely learn, but if YOU don't have a STRONG base to work from and a fair share of tools, this will test you.
I know of at least one person that bought a 1991 that sat for 5 years. He over paid for it ($3500) thinking he could "fix" it. He drove it home with it running horribly. He owned it for 2-3 years, threw another $3000 at it, and he sold it on Craigslist and the new owner towed it away because of the "work" the other guy did. He blasted forward, not having troubleshooting skills, and not enough tools. he was in WAAAY over his head, and his wife was NOT happy. He sold it for $1400 I think, so he lost a bunch of money, time, and did NOT have a pleasant experience.
I bought mine WAAAY cheap, I drove it home. It was abused, needed axles rebuilt, brakes, radiator, hoses, oil leaks, (now fuel tank) and lots of stuff replaced, tires, smelled like dog pee inside, sunroof leaks, and lots of stuff. I have thrown almost $6000 at mine just to make it a daily driver and make it reliable, but I keep encountering things. I walked into mine eyes wide open, FULLY expecting to throw that kind of money at it. Mine is a 96 with the 1FZ. Those have their own issues, and the 91's with the 3FE have their issues. I'm a :banana::banana::banana::banana: mechanic and I'm not afraid of getting into something.
Do it with eyes wide open. Read Slee's guide to buying a Land Cruiser and CruiserDan's Cost of Ownership.
Good Luck with your decision on a 24 year old truck. One more year, and it's officially antique......
Buy it. Drain all fluids. (Oil, coolant, gas) Flush coolant system until it flows clear. Put in new oil. New coolant. New plugs. New battery. Fresh high octane gas. Turn key and see what happens. You are already thinking you are going to replace the motor so what do you have to lose. I like a good gamble.
After you get it running with clean fluids you can see if it is still knocking. Then you can make an educated decision. As it sits now you have no idea what you're dealing with.
The 3FE is about as simple of a motor as there is. They are also incredibly tough. Numerous "mechanics" have told me I have a knock in my motor. Many aren't familiar with the sewing machine/tractor motor that is the 3FE.
FWIW, I'd offer him $700 cash and tow it away.
If you aren't willing to undertake a MAJOR amount of effort, then leave it. These aren't impossible, but you need to be a self starter. Me, personally, I'd take it on, but you need to have a place to work and some level of technical skills. If you don't have the energy, then don't start your son off with a failure.
