I've bought a second 3FE to replace the one I installed in my FJ40 (to minimize the truck's downtime).
So far, I disassembled the long block and sent the parts to a couple local shops (the cylinder head went to a Toyota specialist while the short block and rotating parts went to another shop closer to home).
I got the follow-up phone calls from both shops and am now trying to decide what to do. The block, crank, rods, pistons, cam, etc. all spec out and the shop says I can reuse with standard rings and bearings. Whew. Good news for me...
The head shop called and said they found some weird stuff on the head. All six exhaust valves are toast, as well as the seats and guides. He even told me this was the first 3FE head he's ever seen with several cracked guides. He also said the valves look like they've been beating up the seats so he's going to check all of the springs to make sure they are not too weak and are letting the valves bang around. He also said the deck was out by .005" and recommended we surface it just to be safe.
So, now I need to decide what should be replaced and how much money I want to spend on 'insurance' items and the like. I also have some options on what parts I want to replace with OEM Toyota parts as opposed to the aftermarket stuff: Clevite, SBI, etc.
As a general rule, I'm a hardcore believer in "OEM 'til the grave" mentality but need some feedback on this score from more veteran 'cruiserheads.
3FEs are not as easy to source parts for as one would think - especially where OEM parts are concerned.
Here is a short list of the parts I know I'm going to need for the rebuild and am hoping to get some opinions from you folks on where the extra money should be spent on OEM over aftermarket and where it just doesn't matter.
Engine gasket and seal kit (Cruiser Parts says they have an OEM kit for $350)
Piston ring set (I haven't been able to find a source for STD size factory rings)
Crank bearing set (Is Clevite a good idea or a recipe for disaster?)
Rod bearing set
Wrist pin bushings (Can't find these anywhere... am hoping the machine shop can source some aftermarket)
Freeze plugs
Cam timing gear (Cruiser Parts has a new OEM gear for $110)
Cam bearing set
Oil pump (I have the choice between aftermarket or remanufactured OEM)
New exhaust valves (Here's a biggie. SBI valves run about $18 each. Toyota valves run $40 each. (s it worth the extra cost for Toyota valves?)
Exhaust seats
Intake and exhaust guides and seals
I can have the shop order me an SBI rebuild kit for about $600 and all I'll need to purchase in addition to that are the parts for the cylinder head. But, I know next to nothing about STI and would like to know if I'd be better off sourcing EOM rebuild parts individually.
Rod bearing set
Freeze plugs
Cam bearing set
Exhaust seats
