rebuilder for power steering pump
pskits.com. I did it myself, and it was extremely easy. Cost like $11 with shipping/handling.
How many bananas would you rate this job? Really 11 buck got you all the stuff? I have one laying here that I've debated rebuilding on a rainy day to carry at big events like Cruise Moab. Talk me into it.
DougM
pskits.com shows it around $20.00.
I don't know if the 93 and newer PS pumps are different, but I was pleasurably suprised at how easy this was. The kit comes with the o-rings and bushings, and will only fix the leaks. If your pumps fins are worn out, or something is broken, you'll have to get that seperatly. I imagine that if the seals are shot on the inside, the pump might not work as well, and this kit would solve that problem as well.
The biggest problem I had was getting the old pulley off, I tried various methods, spent about 2 hours messing with it, and finally screwed it up using a 3 jaw pulley puller. Took it to the local tractor repair shop in town, and the farmer used an impact hammer on the back side of the pulley, it took him like 10 seconds, and I felt pretty stupid. Getting the cover off the pump wasn't to hard, you have to push in on it, then get the large snap ring out(the kit comes with this snap ring as well). After that everything just comes apart, you replace the rubber o-rings and main bushing, put it all back together, and your done. The pump has these little metal fins that slide in some grooves, just make sure you put them in facing the right direction, rounded side out, flat side towards the center. Make sure this is correct because I'm going off memory.
Once I had the pulley off, it took less than an hour to break it down, clean it(mainly just the pumps housing), and put everything back together. This job was :banana:.5 bannanas, and like I said, I was suprised at how easy it was, I've had a harder time getting my distributer out to replace its o-ring.
