Rebuild or swap?
Athens, Ga
Quick story. Toyota tech at dealer said don't worry about the code 420 as I recall, I'll clear it for you, (catalytic converter). Last weekend and 1500 miles later number 5 cylinder is pushing 25 psi. I have owned this fine ride about a year, 170K miles, 1997 vintage. Any advice appreciated! Budget minded...
Agreed with @uscmas412 . You need more info. It would surprise me if you had a bad piston ring and needed to tear that deep into the motor. I did my head gasket at 160,000 miles, and the cylinders walls were smooth and clean. If your truck has good maintenance history, you should expect the same. Has the head gasket been done?
If you're using a dealership to clear your codes and you don't do your own work, a swap will be $25K.
Head gasket and head rebuild will be in the $4000 range.
