And it is driving my wife crazy.
My guess is the control on the stalk is not functioning.
Any quick fixes before I take it to the deal?
Michael
Michael
Well, I've pulled the wiper fuse. Then the ECUa, ECUb, main, and battery. Still can't get that wiper to stop.
Michael
Tell me if I'm getting hosed? Feels like I'm getting hosed.
Wife took her 100 into the dealership to ask about the rear wiper. Service Rep says the motor is going out - $340.
Motor going out?? I can't shut the damn thing off, how is the motor going out?
I would figure a switch or modular was going out.
Anyway, and suggestions would be greatly appreciated.
My wife had them take the arm off for now. I'm much more inclined to disconnect the wiper motor than replace it.
I got the same run around from the service manager at the local toyota dealer, "BAD MOTOR" I had already replaced the stalk and relay. So one very expensive motor later, I still had the same problem. Right now I have the relay unplugged and no working rear wiper. So one of these days I need to order a new Body ECU.
Wow, thanks a lot Ayune, you're awesome! This will be on my to-do list over the long weekend. I can't see how I won't be able to figure it out with the info you provided. I'll report back once I check everything.If they can help, here are the electrical diagrams for your 99's rear wiper. It's controlled: stalk switch -> instrument ECU -> wiper relay -> motor. The ECU is behind your radio, the motor & relay (R31) are inside the liftgate.
The rear wiper relay is hideously expensive (P/N 85940-60090), but easy to test once you have access to it. If the relay tests good, then to test the switch & ECU you can remove the radio trim, pull out the radio, and probe the four wires (A16, A17, C3, C12) on the ECU connectors A and C. See what those pins are doing when you move the stalk switch and then you can isolate if the switch is busted or the ECU isn't interpreting correctly.
If this is the culprit, can I free it or does it need to be replaced?Robert, another thing to check, perhaps first, is the cam switch inside the motor (zoomed below). If this switch is stuck to the left it’ll never indicate that the wiper is ‘parked’ and the motor will run til the cows come home. Good luck.
