Rear Wiper Stuck On
Odd problem. My rear wiper is continuously running. The switch is in the off postion. I did not even use it. I used the front ones in the morning then later in the day when I started my truck it came on and will not shut off. This is strange. Any ideas?
Short in the connectors inside the USDS rear quarter.Take apart, clean, re-assemble, repair rust behind left rear wheel so salt spray no longer gets there. I made it to step 2 myself...
Remove the inside handle of rear hatch two screws.
Gently pull the panel off.
Inside you should find connections with blue wires.
Take the two connections apart and clean.
If you still have aproblem you may have to get into the rear headliner as the wiper wiring runs from the top(Inner roof) into the rear hatch door, sometimes this bundle of wires become fatigued form opening and closing the door resulting in shorts.
If you have to go this far make sure you insulte/isolate any remaining wires.
Salt is a major factor here, mine was so bad that it required re-wiring.
While you are at it check the brake light connections under your tire jack. Salt will corrode this and possibly short or smoke causing frustration. Plus this shorting will screw up your remote car starter...
PS If salt/water is the problem it will not hurt to clean your wiper motor and grease.
