Hello All, The channel sub-assy and filler on my rear windows has creeped forward on the lower edge of the glass about an inch over time and I can only lower the windows about 4" before the regulator wheel extends beyond the track causing the window to fall all the way down into the door. I'm planning to replace all the window guides/seals and the channel sub-assys w/filler and the exterior belt moldings.
My question is, do I have to pull the window glass to replace the channel sub-assy's / fillers? if so, how is this done? If not, how is this done?
I've located a variety of posts regarding the seal replacement but none specific to replacing or adjusting the channel sub-assy.
