Rear washer jet
Sandy Utah area
So Im not sure if I ever understood how the washer jets worked on late model FZJ's but when I push the stalk button I get front jets, when it twist it down I get front jets and sometimes rear, when I twist it up I get front jets and sometimes rear and the wiper comes on. I looked on the bottle and noticed only one pump, is there a seperate pump for the rear jet? If not, shy have 3 ways to turn on the jets? and whats controlling the rear jet?
I ask because I was going to temporarily use the rear jet line to hook up an AC condensor spray cooler to try and get a little more oomf out of my AC on these 108 plus days. Any insight on how the jests are hooked up? is there a pump or separate rear bottle?
The front and rear nozzles use the same bottle and pump. There's an electrical control valve inside the engine compartment located below and to the right of the brake master cylinder when looking from front to rear (follow the washer hoses and you'll find it). I've had to replace the pump, that valve, the rear nozzle and blew out the line with air. Life is good.
so you can only get the rear to spray when the fronts spray. hmm.
You should be able to get rear only. Traveling now and not in the 80 so not sure which way to twist but as mentioned the diverter valve is in rear driver corner of engine bay and should be responsible for selectable behavior I may have an extra if yours is bad.
I'd take you up on that. I need rear only.
As I understand it, the washer pump/switch is on the firewall, DS and all you have to do is pull it apart, clean it and put it back together. I think it was @scottryana that did his and described it.
It is not supposed to do F/R at the same time. It's supposed to do one or the other.
Mine does both when I squirt the rear, but front only does the front......
