Rear Upper Adjustable UCA's
Highlands Ranch, CO, Heart in AZ
I have netted 4.5" of rear lift with Slee coils. I do not sense any driveline vibes even though the u-joints are not parallel to each other. I also noticed that the coil seats are not flat. The coils have a slight bow to them. Should I install the adjustable UCA's I bought, or not? I am afraid that If I adjust the pinion down, I will get vibes and have to get a DC rear shaft made. I may add a 1" spacer to the rear coils in the future.
Assuming you installed the Slee 4"?
Adjusting the pinion down should bring the angles back in line on the stock driveshaft, you'd go up to get a DC shaft.
A little bit of coil bow is such a standard feature on lifted rigs it's not to be worried about. Having said that, if the $$$ is not an issue, you can definitely adjust your pinion angle and align the coils better if you want to.
Or go even farther up to bring the angles to equal, and your pinion out of the rocks. No vibes, and no issues with the coils.
-Spike
Ok, thanks. Now I have the $$ for Bilstein 7100's.
