Rear U Bolt Torque Setting
armourguard said:
My rear U Bolts on my FJ40 are loose and i am wondering if anyone new what torque setting and if i should put anti-seize on the U Bolts etc :confused:
I recommend you not loosing your time on how much you should tighten it, I would say, tight it like you would do with a tire, and, for parts that are not usually cheched, It's always better to use some loc tite!
IIRC, 60lbs, which is not near enough. Probably more like 90lbs. I pretty much tighten them as far as I can go with a breaker bar. But some people say the u bolts will stretch if you tighten them to much. But be sure to check them often after that. If they are loose, you might want to check and see if the pin is still in there and in one piece.
According to the Factory chassis and body manual, 50-70 Foot-lbs. But I would definitely go on the tight end of that.
fj40forlife said:
If you have soa you dont have to unload it, But if its stock I would lift the frame
lift it, tighten it (so it will settle ok), put it down, tighten it again and then... ENJOY IT!! thats the whole idea of a TLC, ENJOY!
