Rear Third R&R tutorial
Reno, NV
Website
forum.ih8mud.com
So I'm driving my 40 home from the exhaust shop yesterday and the rear diff starts making a noise like it is possed by a demon from the depths of hell.
I get off the expressway ASAP and get home on surface streets.
When I drained the oil it had a very pretty mettalic look to it, like deep copper metal flake on a show car. So I pull the inspection cover. Laying in the bottom of the dif housing is a copper washer with little dimples on one face. At one time it was around 2" in diameter with maybe a 3/4" hole in the middle and around 1/8" thick. Now it looks like it has been run through a high priced pasta machine which has given it a ruffled apperance.
With six days left before I'm scheduled to go on a trail run (Rubicon) I am going to try to get the third out, to a shop, and back in.
It is a stock 1975 rear axle with an ARB locker. And I've never done this before.
Any words of wisdom from the collective?
That does not sound like anything from inside the ARB....
When the axle was originally tore down, cross shaft removed to remove the c-clips, could one of the spider gear thrust washers have fallen into the bottom of the axle housing and just been missed?
Nothing can/will "fall out" of the ARB, unless there has been a very obvious, catastrophic failure....
Good luck!
-Steve
Sounds like a thrust washer.
It sounds like it went through the ring and pinion gear thus giving it the 'high priced pasta machine' look.
If it were my third, I'd be putting in a new gearset and bearings, and making sure the housing didn't break.
Good luck!
-Steve
I guess that could have happened when we replaced the axle seals.
The washer definatly suffered, it has a place that is worn thin with a break through it.
I do not fully agree with this. I would inspect the gears but would not feel uncomfortable about reusing them. The thrust washer would be pretty "soft" compared to the gears and bearings. The bigger peices wouldn't get into the bearings and would just be eaten for lunch by the gears. It would be worth having a look though.
Well the gear shop won't be able to look at my third member until Monday. So I won't have to pull it out alone. I'm sure one of my Cruiser buddies will give me a hand over the weekend.
With luck they should have it back by Wed. and I can probably get some help putting it back in.
It sounds like what ARB calls a "pinion" thrust washer because it is too small to be a side gear washer (aka spider gear thrust washer). Part number 18 in the ARB manual:
http://www.arbusa.com/alac/alsp/2-rd124.pdf
I don't see why it couldn't fall out when you remove the center pin, but then again, I am not familiar with ARBs.
You would want to double check that it is there as you don't want to run it unlocked for long without it.
Gears and bearings are extremely hard, so it is amazing what they can chew up without significant harm.
