Rear steer?
I've thought about this a bit... Not too much, and no, I haven't done it or been there.
This idea would be a 'trail only' truck. Having this type of setup on the road would be potentially dangerous.
If all you want is 2-3* of turn on the rear, which would tighten up the U turn radius...
Hack the upper and lower control arms on both sides with 4" long (or so) bi-directional hydraulic rams. Run skinny tires.
Not practical and the payoff wouldn't really be worth it. But if you're going buggy... maybe?
IMHO YMMV
Converting a an 80 axle to rear steer seems like quite the feat. If you were really hard core I suppose you could jack it up pretty high and throw some rear steer rockwells under it.
A front D60 could handle the rear of an 80 series . ?
Thinking in rockwels it's think bigger .. so you would need to compensate the wide axle in front too ..
