OlympiaFJ60 said:Mine didn't, built Jan '87 I think. The whole was there, just no threaded insert or the like.
Brandon
89GASHOG said:With lap belts, you're supposed to use a car seat with a shield, and it doesn't sound like that's what you're describing here. Maybe so. Anyway, the belt goes over the top of the shield, preventing ejection of the nipper in the event of an accident.
GeoRoss said:Sorry to dredge up this old thread.
Please let me know if I have this correct.
1. Sometime in 89 the FJ62 came equiped with rear shoulder belts (Retractable and/or non-retractable?).
2. All FJ62 models come with the threaded hole in the C-pillar allowing for the 'easy' addition of rear shoulder belts. (Retractable and/or non-retractable?)
3. All FJ60's come with a hole in the C-pillar that is not threaded. You can add seat belts, but you will need to do some sort of modification.
, but only if your kids are out of hearing range.Carpe Discus said:According to the U.S. Department of Transportation, you are to "Never use a lap belt only" with a belt-positioning booster. Those are the no-back boosters for 4-8 years or so. The high-back booster/harness that can be used with younger ones apparently can be used with just a lap belt, but that appears to be because they have a harness themselves. So basically, you need a shoulder belt if they're using the vehicle belts for restraint.
OlympiaFJ60 said:On a 60 (and maybe the first 62's), if you add the retractable shoulder belt, you need to do alot more work, creating the mounting space for the retractor unit. For the fixed belts you just need to bolt the top of the shoulder belt to the C pillar becouse the retractor is still in the lap belt.
On the booster seats, mine states to not use with fixed shoulder belts.
HTH
Brandon
landtoy80 said:Any pic of the 3 point kit from Toyota, the non retractable one that is?
How does it work?
Does it adjust like the middle seat belt?
azaussie said:I know this is an old thread but can anyone confirm that all 62's have the threaded hole in the c-pilar.
