Rear Rotor Removal?
Secesh
Can't find FSM and don't have PDF file for rear rotor removal. Need to replace. Whack with hammer and pull or what? Thanks.
Also, anybody using Power Slot rotors? Have them on my Superduty and they are great. Suggestions welcome.
on the front of the rotor you will see a rubber plug. Rotate that plug to the 6:00 o'clock posotion and pull it out. You will now have access to the star adjusted for the emergency brakes. Using a screw driver rotate the star adjusted to relax the brakes and then slide the rotor off. If while turning the adjuster the rotor gets stiff to move you are going the wrong way with it.
Thanks Rick!
How ya doin' anyway? Moved last year and haven't had time for posting or any work on the LC in ages. Can't find my FSM and my tech site membership is expired.
Can't find Power Slot for rear rotors so I guess I'll be calling Dan and stay with OEM.
Take care and thanks again.
Dave
