I have been thinking about my rear quarter storage panel and came across this picture on landcruiserclub.net by user gytman and thought the idea interesting of replacing the interior trim and putting a recessed a box into it. I believe this one sticks out more then I like but why could you not make it stick more into the quarter? Has anyone here done anything similar to this?
UPDATE: 6-22-2017 Okie dokie folks, I don't have 100% of the details worked out because I had a last minute idea I want to try and include. But I have enough info to set a price and start production within the next week or so. The new metal shop I've been working with has brought up a couple of...
I cut a small platform out of plywood that fits in the bottom on the right rear fender area. I popped the liner out of the cubbyhole so that it's door is now the opening to the storage area. It's mostly emergency/survival gear in there, but it's available and no longer taking up space that might tempt me to leave it at home.
I can't find the crappy pic I took of it right now, but will post if I find it. Best thing to do to get it right quickly is to use a piece of cardboard and cut it as a pattern to use to cut the plywood once you've trimmed it to fit well.
Even if the rocker under your fender is still watertight, you don't really want to just chuck stuff in there to just lay in the bottom. That's because, depending on your environment, condensation can happen on the inside of the fender and run down to pool in the bottom. This dries out pretty well when there's nothing but air stowed inside, but you don't want your gear absorbing it and keeping it from drying out easily.
