Hey guys, my window keeps coming off the track. As I watch it the little guide wheel pops off the end of the track at about mid way of the window travel. Is it just one wheel that guides this track or has something broken off? Any help would be appreciated.
Both my rear windows do that also. What I plan to do (read-if I ever get off my arse and do it) is weld a small tab at the end of the track.
The track is to short and right at mid point it is fully extended. It can then drop out of the track. My mechanic buddy tells me it's a fairly common thing on older Toyotas.
Until I fix it, I just don't roll down the rear windows. I have gotten good at pulling the door panel and fixing it in about 5-10 minutes.
Ha! Mine did that about a week ago. I took the window out and took that track off the window and put it back on closer to the edge of the glass so that little guide wheel had enough track to travel on.
I ran into a little problem however. I used soapy water per the FSM to get the track back on the bottom edge of the window. I put everything back together and tested it. And yep, that rubber on the track that goes over the window was still slippery and the damn thing completely pulled off the window.
Luckily I was able to put it back on without pulling the window out again. Then I used vice grips to compress the metal around the glass a bit.
You can just grab the track on the bottom of the window and move it without taking the window out. It is hard to move, but I'm sure its much easier than taking the whole thing out.
place a wooden hammer handle in the window holder and give a slight knock to slide it along the window. i also greased everything in there: motor, guide, wheel, runner. no problems so far and at least a full second faster than the other window.
Thanks for the responses. I welded a beed at the end of the track and moved the track over a bit so it would not come out. Your right it was a b**** to get the track back on the window
