Rear overhead storage?!?
Taylorsville Utah
I know I have seen some people using it in the rear of the 80, But i cant seem to find it in search. I remember it being a net or others have used a metal plate that attached to the rear most grab handles.
Anyone, Im sure Im just not choosing the correct words in search.
Thanks
I used to just have a fixed shelf but now have a combination fixed & slide out. The forward section of the shelf is fixed and has things like my indertor, computer, amps etc on it. The rear section, which is the largest, is on a pivoting slide arrangement so that I can lower the end nearest the tail gate and slide it out till it hits some stops. I keep my stove, cutlery, mugs etc in that and with it slid out and pivoted down it makes an easy access unit even with the tailgate down to cook on. Only downside is it then blocks most of the rear access so a rear fridge slide would clash with it. It's currently all wood because that was the easiest to work with for a prototype but now I'm happy with the concept I'll re-make from aluminium.
I can tell by the dents that you don't have the newest looking cruiser around, but it does look like you have some very innovative and creative modifications. When are you doing a ROTW? Nice looking drawers....I mean the storage ones! :)
I don't know how good a description I can give, it's very low tech but it's getting the job done.
There's a support piece either side of the shelfs with a long slot in it. At the back of each side of the main shelf there's a long bolt sticking out which locates in the slot. The other end is supported by some hooks. When the hooks are released the self can pivot down and also be pulled along the slots. The sides of the main shelf are a bit shorter than the side support panels. That's so the other shelf can also be supported, again with long bolts but this time just in to a hole not a slot. This smaller shelf also pivots for access to my computer etc for servicing. It fits between the sides of the main shelf.
Maybe a picture of it in the up position will help. If you compare open and closed you should see what I've done.
The side panels are held up by some angle that I riveted to the inside of the roof which probably not everyone wants to do :D I did look at my wife's 80 which we tend to keep in better shape to see how I could put a shelf in that without making holes in the roof. I'm a fan of putting all my crap down each side of the main load area so I think a H shape of small section square steel tube from floor to roof on each side, with the cross bar at shelf height, and run two pieces of bar from there to the grab handle bolts should be quite a solid frame to build the rest on. The same frame would make a good starting point for lower shelfs or draws
Grilled Cheese??
M-A-F or Downey used to sell an overhead console-style storage box that fit above the rear hatch opening. The doors on it faced forward so you could access it from the second row seats. It was big enough for maps, first aid kit, and similar small items. They haven't offered it in yonks. I'd buy one if anyone could find the manufacturer.
