Rear Locker repairs
Atlanta GA
Working on my rear Locker pretty sure it was the magnets. Should the shaft be easy to move? Can hardly move it with a pry bar wondering if I'm just putting it in a bind. Also source for the little gaskets ?
What Phil said on the shaft - it should be easy peasey to slide it.
If your able to clean up both the channels the O-ring rides (and get a new O-ring from an Ace or local hydro shop) maybe add some RTV in rhe spots rhe corrosion made the milling mushy.
Not sure if it's corrosion or just water/grease beads making the white spots, if corrosion then I'd get it all out of the motor chamber to lengthen lifespan.
undo that bolt, it will be stiff to remove because it's got blue locktite on it and slightly longish, once that is out you can pull the locker shaft out when the actuator housing bolts are undone (in your photos you still have several actuator housing bolts to go before you can pull it), then when you move a tire or driveshaft with one hand and rotating you can press on that shift fork lever now that the shaft is gone and you'll feel the locker crown seat as the tire rotates, have to make about a fifth of a turn or so of the tire if it's not in line
the trick is the diff / tire / driveshaft has to be rotating for the engagement to happen
if it doesn't engage you've got other issues
see this thread and other links within and download that PDF in the first post
Repairing Differential E-Lockers
