- Joined
- Nov 10, 2009
- Threads
- 21
- Messages
- 297
Search gave no help unfortunately, but surely I am not the first one to come across this? All searches point to the 3rd light leak and water in the cargo area, that is not my issue.
Tow hitch specialist called me in to his shop during the install. He needed to drill a hole in my body for the install and when he did, a few gallons of water came out.....
We checked it out: there is a drain plug on the undercarriage. Pulled that out, more water. I assume it is also to prevent too much water ingress during deep crossings. Anyway, ton of water in there. We assume it's the gaskets on the rear lights, looking from the side with open hatch one can see there is a slight "crack"; enough to let water into the body cavity.
Anyone encountered this before? I will pull the lights ASAP, it's just 2 screws from the side I think, but I need to replace the gaskets most likely. I would prefer some sort of single sided tape to the light, thick enough and pliable enough to create a good seal against the body.
