Rear latch won't lock
hello everyone,
Since I bought my cruiser 5 years ago I have not been able to lock my hatch through the FOB. This is a project I have put off for too long!! I did some research and tore into the project. I can feel that the lock tries to move, but won't lock in either direction with the FOB. I am able to lock it by hand with no problem. Nothing appears to be binding and I don't have to use force when doing it by hand. I pulled the actuator apart and looked for the signs of damage that others have described and found none. I also tested the motor and it spins with force. It doesn't look dirty and I have also lubed it. The other weird thing is my key won't turn the lock either!! Is there something that I am missing?? Thanks for any help
Try some silicone lube in the lock and put your key in it. Work it in and out. I had a similar issue with mine (believe it or not I didn't even realize that the lock was there!). 23 years of not using it and it wouldn't budge. A little silicone line and finesse and it works like new!
I will give it a shot!
Tried the silicone and no luck!
There's a part that has split and no longer will turn the shaft to move the lock mechanism.
I cleaned mine up real well and epoxied it with some 3M 2216 epoxy, and it works great now.
Look for a crack where the arrow points, or somewhere near there. Pull the arm off, clean it and the shaft, and glue it with a good epoxy. 5 minute is likely too brittle for this application. YMMV.
I know I had to work it multiple times. Letting it sit and soak with the hatch open so that the lock was laying flat, essentially.
I know others have had issues with their key being worn down. Now, I know that won't affect the key fob operation at all...
I pulled the actuator apart and I could just grab that arm and move it up and down without anything else moving. Is that normal? I will inspect it closer tomorrow!
I did a write up on that fix a few years ago when I got trapped in the cargo area of my 80. Let me see if I can find it. It cost about 40 cents to fix it.
That would be awesome!! Thanks
