Well I'm new to the 80 section .I have owned lots of cruisers over the years and finally went south of the border and picked up a 93 for my wife (replacing a landrover) I went to get a provincial inspection and the only thing other than the daytime running lights (which I did before hand) was the rear brakes . There were worn and rotors and pads and need to be replaced . I have the parts coming tomorrow and have already torn it down . My question is should there be any in/out play in the rear hubs ? I can move each hub in and out about a 32nd of an inch . There is no side to side movement though. The truck has 167k on it and I don't think anyone has ever been in there. I'm pretty sure there shouldn't be any play and I'll probably inspect and repack the bearings anyway but just checking.
This is fairly typical for most US 80's as most dealerships do not know that some of the 80 had a full floater rear end. The owners manual nor the FSM show any service intervals for the full floater rear. So if you look at the front axle and it recommended intervals for cleaning and repacking the front wheel bearings you will be just fine if you make it the same for the rear axle.
The things I would look at when doing the rear axle is how far the race of the wheel bearing has messed up the spindle seat( the area where the wheel bearing race rides against)? You will know this when you either adjust it (before you repack) to see if you have adjustment(which takes a special tool).
93 service manuals do not normally take into all the advances of the 93 and up 80 series. A 94 manual will serve you better for most of your needs.
Good luck Robbie
