Rear Heater T ideas needed
Thanks to a lister here I am adding a rear heater to my cold 40. I have a set of hard lines but may just use heater hose. I do not have the "T" fitting at the firewall/front heater for attaching the lines for rear. I was hoping someone had a great idea for a way to add the rear heater fittings and maybe even make it removable in the summer (I know my kids will crush it) I searched here and $OR, but didn't find what I was looking for. Thanks Jay in NY
I would imagine the ideal way to do it would be to find the hard line T section from a cruiser with the rear heater and use that. Otherwise maybe you can find some sort of pipe fitting that your heater hose will fit over alright.
When I take my rear heater out I just use rubber fitting caps, you can buy them at any auto parts store.
Check some of the other cruiser shops like Proffits or Classic Cruisers. They usually have minor parts a lot cheaper than $or and are easy to deal with.
HTH and good luck.
Cruiser Outfitters......Curt is the best!
I used 1/2 inch copper T with 1 1/2 inches of copper tubing soldered in. Put a straight connector soldered on the ends. Slide 5/8 heater hose over and clamp.
The T's are all over the place used, especially in warmer climates. I had a set of hard lines and they leaked like crazy. I ended up just running hoses. I can just see the look on the dude at a hydraulic shop...you want whaaaat?
