rear heater question
San Antonio TX
Is there a way to test the rear heater out of the vehicle?
Test what?
If the motor spins? Put power and ground to the motor...if it spins, you are good to go.
If the heater core leaks or is plugged?
Take it to a radiator shop and have them cook it out, or go the muratic acid route and flush it yourself, and then make plugs and pressurize it and see if it leaks.
Good luck!
-Steve
If you do pressure test it yourself make sure the regulator on your compressor is set pretty low say 10-15 lbs. If you put 100 PSI on that core it will probably rupture...
