Rear heater leak
nova scotia
Hey guys,
Looking for advice on a leaking rear heater. It's leaking around the control lever/switch. Just wondering if I can or should replace just this or do I need to change the whole core. Lots of hear from it and it past a pressure test perfect..... Just leaking from the control lever.
Thanks!
Hey guys,
Thanks!
Pull out and have radiator shop re solder. Or bypass at the heater outlet on firewall.
Thanks for the advise.
The heater was bypassed on the firewall to start with and I'm trying to get it back in service. Re fitted it ok but had the leaks around the lever seals, which can't be soldered because of no access.
Just trying to find out if the whole Core should be replaced or if just the control switch is worth replacing.
Rear heater is very easy to access, pull apart, and address the leak.
