Rear heater disconnect?
Colorado
New 40 owner. Beginning to dial in my new(to me) 76 fj40. I want to take out the rear heater unit to provide more space for a kayak box...search the manuals and cannot figure it out. Any help would be appreciated. I am BRAND NEW to this site and have not figure it completely out....maybe a private message would work best with a rely to start. Thanx
Look at your heater under the dash. There are two 'T' shaped hose connections where the two hoses from the engine are split out to go to the rear heater.
Take out those two connectors and connect the from engine hoses directly to the underdash heater and be done.
You don't need any cockamamie u-shaped rube goldberg silliness.
Realize this: without the rear heater you will not have cabin heat when trying to defrost the windshield. There isn't a two way up and down at the same time mode like your Cadillac has.
Agree'd this is a much better idea, I would still look into replacing the fluids.
Good luck again:cheers:
Just fab an overhead "skidplate" mounted to the same captive nuts in the floor utilized by the rear heater mount. Seat bracket bolts come to mind, as well. Maybe incorporate a "cage" for the back of the heater to keep stuff from touching the core's blower outlets but still maintain air passage. Add some of that heat insulating adhesive stuff with aluminum facing sold everywhere to eliminate all heat concerns.
As I write this, I wonder if you could simply adhere some aluminum-faced Dynamat, Brownbread, etc, to the top & sides of the heater and be done with it. How likely would melting occur at the rear blower outlets? Perhaps do a temp test there to see. I think I'll do this myself. Thanks for inspiring a little brainstorming.
stormcruiser,
You don't have any room in your p-mailbox so I answered your questions like so:
Ummm, I'm not sure. You aren't doing anything to the defrost ducts when you disconnect the heater in the rear. Everything would be the same except that there would no longer be the two hoses that route through the rear heater.
As to covering/protecting that back heater - A lot of different methods of building a cage over the heater have been used. Anything made of steel or other material that won't melt will do so long as the protection device isn't closed and not allowing air to reach the heater core. How it's done sort of depends on what a person plans to have back there.
Also, there's no reason that that heater can't be moved. I've seen them under driver seats and under a custom mount for a center console sort of thing made using an ammo can. Lots of choices.
Good luck!
-Ken
Unlikely you're going to melt anything, it's just hot water, after all. I wouldn't worry about that part of it, at least.
Depends, Texx. It can get the metal top piece hot enough to melt a nylon rain jacket, Burnt a hole right through after the truck was parked and we left. My wife is pretty careful about that heater now, and I was glad the jacket was cheap. Opened the door to a high stink of molten plastic and I thought something must have fried under the dash. Generally, it sucked.
Why not just put a ball valve on the rear heater line? shut it off when you don't want it...
i took mine out today! its just in the way! I put a U Shaped rubber hose in their, but i also shoved a piece of rubber in their to block the flow, this way the hot water is not going back to the engine before it heats up the core..
and the rear heater WILL Melt pretty much anything meltable.. mine has remnances of jackets, Floormats, ect..
